Gauntlet Legends won't run in high res
Shou
Roppongi Hills, Tokyo, Japan
I've got a Gauntlet Legends board where I've set the dip (sw 2 on U12) to on so it should play in VGA but it keeps booting up in 15kHz. Going to test mode confirms that the dip is set correctly.
The battery is dead on the board and I've swapped the HDD out for a CF equivalent so not sure if that's the cause.
I thought gauntlet was a medium rez game..
I see the dip switch says vga for dip 2. maybe dip 1 has to be on or off as it deals with standard and medium rez..
I don't think the batter of the CF would effect it..
