Gauntlet legends error code?
MKtrill
lorton, Virginia
I switch on gauntlet and the leds cycle once through all the numbers, and then lands and stays on 6..... Hdd is spinning, however no picture, or sounds...... Any idea if this is n easy fix? Maybe hd problem? Or something more serious such as game board pcb..... Or graphics card......
He wants 270 for it as-is......
If you tell me id be spending way more money then ill let it go........
6 is bad hard drive.
They can easily be bought from Ebay for about $30-$50. I think you need to have the right image though.
The danger is you not knowing what else isn't working. If you replace the HD and the graphics card doesn't work or the monitor is hosed you're in trouble.
Note that this could also be an issue where the HD isn't hooked up right. Not sure I'd try that in front of him because if that fixes it, the price will surely go up. :)
Lol true that! Thanks for the help, ive decided to pick up one near by for 400 fully working eith a brand new 27" tri res monitor..... Cant beat that!
No, not with a new monitor as-described. The monitor alone would cost close to that.
