ryandimx
Gauntlet Legends board set with upgrade Roms and compact flash for Dark Legacy.
With the Legends hard drive and Roms my numbered led (3) on the cpu gets to 6 indicating a hard drive error. Led 1 on the I/o will come on for a flash then turns off indicating the boot ROM is not booting. Hard drive is still spinning for a bit then stops and led 2 turns off indicating no hard drive activity.
So
Change out the hard drive and Roms with compact flash and dark legacy upgrade.
Same issues. Get to 6 and no boot led. No led 2 on the CPU indicating no compact flash activity.
Voltages test good, everything looks to be hooked up properly.
All connections between boards have been cleaned off with brasso and alcohol. Everything is in tight. Anything that can be reseated has been. Changed out the socket for the boot ROM and same result.
So
