Gauntlet DL Issue
RedWarrior80
Erie, Pennsylvania
I have a Gauntlet DL showcase cabinet that currently will not fully load....gets to about 60% and then restarts......Prior to this there was a loud buzzing sound coming from the speaker when game was on and running. Any thoughts to the issues?
well voltages should be 5.05-5.10v I would say and obviously the 12v should be around the same, without either of those, chances the game wont boot and just throw a fit, if you can get it into test mode, you should be able to test the Hard Drive, if you have good voltages then I would say a bad Hard Drive, which is an easy fix as many people can offer the Compact Flash alternative here on KLOV
check out the numeric LED display on the motherboard while the game is powering up and it'll run through a sequence of digits which will tell you what it's doing when it runs into a problem.
It may very well count through numbers and then start flashing U.E. You want the number that its at before it starts flashing the U.E. and that'll tell you where the problem lies.
Likely culprits are the hard drive and video card. Or the power supply.
I had the same issue and had o buy a $ 65.00 power supply and issue was fixed after that. I did check my voltages and they where too low, these vegas boards are a major PITA.
twistedquarter has them too
