The other day my Gauntlet Dark Legacy machine started resetting itself constantly - it was on and had worked fine throughout the day until the afternoon when this began happening. When it reset, it would get into the attract mode and then restart again. I wondered at first if it was an issue with the HDD but I turned it off for a little while to make sure that it wasn't having an overheating issue. When I turned it back on, there was no response from the game and when I check inside I can hear the monitor getting power and the marquee light gets power as well but one of the red LED's near the JAMMA dimly lights up for a second then goes dark, the fans aren't running and there is no other response from the board until I power it off, where a couple of lights on the board then flare up, I hear a brief buzzing noise then it's off completely.
So this has me a little baffled as could it be that the power supply is not giving the game enough power or is it a board issue since the game would reset itself prior to not responding at all?
Thanks in advance
Thanks in advance
