Gauntlet Dark Legacy - video card?
modessitt
Austin, Texas
I rebuilt a monitor chassis for someone who had a very dark picture that was mostly red. When I got it I found the colors to be way too bright and a cold solder joint on the G2 to the neckboard. Fixed it, and totally recapped it. Tested it and had a great picture.
Sent it back and he installed it and got the same picture.
Now, before we do any troubleshooting with the monitor, does GDL use a video card that could be the problem? And if so, is it a standard video card that can be replaced, or is it special?
Thanks....
I believe it used a quantum3d card, from 3dfx. not sure how easily replaceable it is though. quantum3d were the high end model of 3dfx voodoo cards.
EDIT: ok let me rephrase that. I'm not sure how easy it would be to find a replacement. swapping it out is probably a piece of cake.
The vegas board can be switched from low to med res with dipswitch settings, although I have found that it still puts out a higher end signal that most older monitors that are standard res cant pick up well.
The video card is an obsidian3d card, theres a guy on ebay that is selling 100 of them for like 50 bucks each.
Well, the game has a K7500 in it, and I'd assume it worked fine at some point, but I'm not sure. I'll let the guy know about the Ebay thing. Got a link?
He says he has a couple other boardsets, so he's going to try another to see if it works better.
He's a member here, so if he needs a video card, I'll direct him here....
I am the customer "modessitt" is talking about. I was going to replace the complete game boad set with a known working DL set.
I got stuck with some screws I can not remove... It looks like I need to remove the backing plate to get it out.
in the short term I replaced the video card only and it made no change.
I think my next step is to attach my NIB Jrok board to the monitor to see how it looks.
The more I mess with games / monitors the more i like "Pinball"!
Fun Fun,
Fun Fun,
Your monitor is a medium-res. not sure that the Jrok board has that ability.
And does the DL setup have a VGA output? if so, connect a computer monitor, or flip the video card dip switches to standard-res and try it with a regular monitor.
Unless the tube is the issue.....
Well The JROK board looks the same as the DL same crappy mostly red color.. and dark
John
Hmm. The chassis looked fine connected here:
Was this game EVER working okay? Or did you buy it with this issue?
Know anyone nearby that has a tube rejuvenator so they can check the tube?
It was never working. I picked it up with this issue.
I will try and track one down. I have a g07 tube that I need to try to rejuvenate as well.
