Gauntlet Dark Legacy or Dungeons & Dragons: Towers of Doom?
rcaido
Olympia, Washington
Hi i want to get a 4 player arcade but wanted to see which one i should get? My plan is to put Wrestlefest board into one of these, would it be compatible? Also maybe get a Blitz/NBA showtime PCB too...Will there be any conflicts in doing this? Or any other 4 player games?
Well, those two machines are not as similar as you may think. The single biggest difference is the joysticks. D&D uses 8 way sticks while GL uses 49 way. Wrestlefest uses 8 way, but Blitz usually uses the 49 way. If you are planning to get two cabs and want to be able to play all of these games I suggest getting the D&D and Blitz cabs.
All of that being said I am fairly certain that you will need to build new wiring harnesses for the swapped in boards. D&D and Wrestlefest Player 3 and 4 controls are wired differently and the harnesses are not interchangeable.
So i asked the seller that he can play his Wrestlefest on his Gauntlet Legend cab. Does that mean he has a duel monitor? Also 49 way controls works w/ 8 way games?
