brutal.
you wouldn't happen to have another power supply laying around by chance would you?
your voltage seems good, maybe a tad low on the I/O side though. what's your test point, are you doing on the JAMMA harness or the actual fingers on the board? as stated above, the power section of the JAMMA edge has a tendency to get nuked on these, which had me concerned when I pulled my Sportstation board out that was listed as a "working pull" and saw that. it worked though, and it's apparently normal on these.
I think the target +5 voltage is 5.10, or maybe 5.15. they're pretty picky I'm told, I'm very fortunate my install was a direct drop-in and I didn't have to fuck with anything.
if it means anything though, the Road Burners (also Atari Vegas) at my family's arcade had a power supply that was probably NEVER adjusted, and it wasn't until one night I was playing my KI that was next to it that I noticed RB resetting and posting an error like "3 strikes and you're out!" signifying a disk read error. when I metered the +5, it was running at 4.86V -- it ran like that for a year! after adjusting it within proper range, the game never errored again.
so, I guess you can go under... but not over?
the good news thus far is it seems your drive and all your roms are intact, it's just looking like trying to get the bastard to "start" is the problem.
btw, does anyone know if the VGA cable is unplugged, would it prevent the game from starting? much like if the video card is bad, the game won't load either. did you try reseating all the boards? I think you said you did, but that was 4 pages ago.
