vicjw66
Weird, but after putting the battery back in and putting the original hard drive back in the game is up and running in mine...for how long I'm not sure.
I have checked the voltages at the jamma connector on the PCB and at the Pwr Supply. What voltage am I looking for at the ROMs? By the way, do you know where the battery is that they were speaking of earlier in the posts? These are all Atari PCBs by the way. Not sure if that makes a difference, but I believe there are some Midway PCBs also.
I have no idea of what a stuck .8 means.
I'd be thinking about finding someone else local and seeing if your boards will work in their machine. If it does then you have a power or connector issue.
Or you could try a wild stab in the dark and try buying a complete new wiring harness and seeing if that helps. Option 1 is your best bet.
If you'll post some pics of your boards we can point out the battery. I just got mine all back together last week and don't want to open it all back up again.
Wait a minute -- switch 3 or switch 4 on U12?
The GL manual and the GDL conversion manual both list switch 4 on U12 as the switch 'normally open or normally closed' option.
Switch 3 is the 49-way or 8-way switch.
Incredibly cool information that I've not seen elsewhere regarding the switches, thanks!
Now the $1,000,000 question is if the switch 4 trick works on the dedicated boards as well as the conversion boards? And does it work on all of the versions of the dedicated and conversion boards or just after a certain point in production?
I'll test this on mine and confirm your theory (at least partly) but I just got the damned thing closed up after about 6 months so I'm not eager to open it right back up again to do testing.
Atari documentation really sucks, apparently.
Some of the conversion kits came with boards set for 8 way stick operation (and the buttons on the standard wires). Some of them came prepped for 49 way sticks.
These are all great catches on your part.
When you swap out GDL on a GL board set, do you just need the boot ROM chip (U18), the PIC chip (U37), and the correct GDL hard drive with same version to make the swap? I thought I read about someone talking about an additional audio chip? Would this be a chip needed also, or are they likely talking about swapping from something like War: Final Assault to either version of Gauntlet? So I guess I mean, is there an audio chip both GL and GDL use that doesn't work with other Vegas 777 games?
