Garage at Capacity
Paul Olson
Reno, Nevada
Millipede Beeps
The manual says that the beeps will be repeated, but mine aren't. Sometimes the game resets with no beeps, other times it resets with 4 beeps. It sounds like there is a very slight pause in the middle of the beeps, so maybe it is 2 beeps repeating once?
Either way, it looks like I need to find some 2114 ram. I am just wondering if it is supposed to be repeating the beeps when it resets, or is that only in test mode? I tried test mode once, but apparently the ram was working fine just then.
The game was working great until last week when this started. It will still play for hours sometimes.
Edit: I reused this thread when I moved a post to the right forum, so the first couple of comments won't make much sense now. :)
Nice set up, hoping this first arcade machine I have leads to many more.
I posted the garage pic in the wrong forum, so I moved it. I had a tech question, so I just reused this thread.
Try swapping the Pokeys and cycle power. See if the beeps are more coherent then. Could be a bad 2114, but IIRC the beeps indicate the 2101 screen RAM.
