Gameroom electrical wiring..
descrentl
Redford, Michigan
This is problably going to be a dumb question, but when prewiring a 2 gang box (4 plugs), how many lines do I run to the box? Im going to wire each outlet to a dedicated breaker. So, do I wire one, and then daisy chain the other. Any info will help. Thanks
If you want each plug on its own breaker than you need two lines from the panel.
If you want to pull just one line from the panel then just "daisy chain " between the two plugs.
Yeh, thats what I was looking for. I meant 1 breaker per 4 plugs. Ok, cool. Thanks
