mrARCADIAN
I recent acquired a 512 in 1, and I started reading that the chips doesnt matter as long as it a 8gb chip SD well. I got an image from a site.
okay first off My chip works fine no issue.
But when I put the 412 vertical, i hear the music i can get into setup, but the games wont play i got it to work one time, I tried to chaNGE it to upright mode and it doesnt works just goes into reboot mode the game elf freezes then reboot back into it. I have to reimage the file in order for it to work again, but i can get into the main screen but none of the control works I thought it was the bootloader, but i tried several ones.
Any help i would appreciate very much. I removed the ground wire and restarted but this is the thing the setup works fine i can do all the setting and testing fine everything checks out.
I juist find it wierd once i get the game running nothing works sometime the button will change the screen and not the joysticks.
is the image bad!??! why does it boot up fine after making a new sd card, my original works fine.
Thanks again.. I hope i put this in the right section..
