Galaxian to Ms Pac?
I believe you would have to add a couple wires and reroute a couple more. You can compare pinouts on crazy kong.
There's a bunch of differences it looks like. There's a guy selling a Ms. Pac in a Galaxian cab around here and I wanted to know what to look out for.
It shouldn't be too horribly different. I had a Galaxian PCB that was rigged to play in a Pac/Ms. Pac cabinet. IIRC, (as mentioned previously), Fire is up and the sound pins are different. I had them jumpered to the correct spots and Fire was rerouted to 2P Start. It worked pretty well that way until the board konked out.
2 wires need to be swapped, and youll need to add a 4-way joystick and add a wire for down. Fire acts as UP. I believe one of the speaker wires gets swapped with a sync or common ground, not sure which. Ive tried a Pac PCB in a Galaxian before and it works fine aside from lack of sound and DOWN, which can be solved with a couple simple wire swaps.
Hopefully this guy gets back to me. I want to be able to pop my Beastie Feastie kit into it. It'll be pretty cool in the galaxian cab an it's already wired correctly as the BF is on a Ms Pac board.
