galaxian fuse trouble
kfuller19
Permanently Banned
Donor 4 years: 2012-2015
auburn, Georgia
according to this chart its number 8 that is blowing
I recently replaced the power transformer from one i had laying around, I know its good.
So im still having the same probelm. Anyone know whats a common problem that will blow this fuse?
thanks in advance
thanks in advance
measure the ac voltage into the transformer and the ac voltage out of the transformer. Look at the other side of the fuse holder for anything that may be shorting to ground.
Measure the resistance (power off) from each side of the fuse holder and ground...you are looking for a possible short there.
That either powers your monitor or marquee lights. I would guess its a monitor problem but usually the fuse on the monitor will blow first.
Check the wiring diagram and see what that fuse is for.
