Galaga won't FIRE...
S4Patrick
Michigan
Hello...
My Galaga decided not to FIRE anymore.
The Player 1 & Player 2 buttons, as well as the left-right joystick movement all work.
But the FIRE button is not firing.
I checked the connections at the control panel and all look good.
Can anyone make some suggestions/ share experiences with this type of problem?
Where should I look/ what should I considering doing to get the FIRE button back up?
Thanks!
~Patrick
Check the connector in the harness for the rapid fire board... it's usualy replaced by a little jumper board... bad connections there = no fire.
Thanks HudsonArcade!
Your suggestion was the fix....is it some sort of a "loose" connection, as I couldn't see anything physically wrong with the wire harness connection....?
Thanks again...
~Patrick
