Galaga vs. Ms. Pac cabinet
the coin door opening on a galaga cabinet is higher up on the coin door panel to accomodate the kick plate art, and galaga has a wood shelf/box to hold the coin bucket. Mspac has 4 carriage bolts in the face of the machine, and has a wireframe basket to hold the coin bucket. Also, the area behind the control panel is a bit different, and the monitor mounting is slightly off between the two.
Thanks alot Brett. I have heard this exact thing and didnt want to look like a newb if i pointed that out.
Hope your recovery is going great!
Thanks! It hurts pretty bad today. I had went to Jpopsons over the winter and measured all the differences on his dedicated Mspac. I knew if i only changed the coin door panel, that it probably wasnt the only difference. The monitor is shifted in mspac, as the artwork on the bottom of the bezel is taller.
