Galaga ?'s
akasam9
san pedro, California
I need to replace the power switch on the top of the cab and also the test switch behind the coin door but dont know the power and amps for these things. I am guessing 110 for the power switch but amps??? and the test switch I have no idea.. Any help out there?? This is a dedicated cab not JAMMA. Thanks
You might find an amp rating for the entire cab on a label or plate somewhere. I'm not familiar with Galaga cabs. I would imagine if something can handle 2 amps (I think most 110 switches can), your fine.
For the test switch, I doubt you need much. Usually that's typical 5v running through there, I think.
