Galaga mini label
JoeB1355
Seymour, Tennessee
What does the top fuse label say?
Might be the same on an upright as well. I found pics out on the inet none close enough to read the paper though!
Dude its for the 2 fuses
You can see above the the A in amp still visible is not in the same place....
So the top one you can't read is 2 AMP (according to the schematics) and the bottom is 2 1/2 AMP,
The top is for the monitor so does it say "MON VOLTS" or something like that since the bottom says LINE VOLTS or do they both say LINE VOLTS?
Just (finally) checked, and the label on mine got folded under itself at the factory, then stapled down… So I can't make out eveything it says, either. "15 volts ?? amp slo-blo" is what I can read.
According to the schematic, the fuses are 2 & 2½ amp.
I recently picked up a super nice all original Galaga UR (except for a new CPO)...
Don't know if this will help at all, but I took pics of all of the labels on the PSU for you. The label listing the fuses has three listings instead of your two and is also in a different font.
The first picture is the PSU serial number. Second pic is of a lone fuse near the front of the PSU block. Third picture is similar to your label, it's on the back of the block near a bank of three fuses.
Let me know if you want me to photo anything else that could be of use!
