pinballdirec
If I check the 5 volt on the main board it is about 4.75 volts, if I check it on the switching power supply it is 5.22. The game is playing but is flaky.
I ran a couple jumper wires from the power supply to the connector on the board and still had low voltage.
Should I just replace both connector, or should I run a new wire or any other ideas?
Kevin
Kevin
