Galaga keeps blowing GFI
Mr Do
Donor 6 years: 2012-2013, 2015-2016, 2019, 2025
Basking Ridge, New Jersey
Just picked up a Galaga and tried it at sellers location. Worked.
Brought it home and plugged it in and it keeps blowing GFI in garage.
I reset GFI and the light and vacuum works, but game keeps blowing wall GFI.
I noticed the wires out of the filter are fried. The ground and brown one. I did not check under the blue wires tape. Why???
I turned on the game switch and interlock switch. Could one of those be bad causing a short?
Plug is likely miswired on the game.
Has it been replaced?
Edit:
Looking at the picture, the plug is definitely miswired.
Neutral is going to the earth ground on the filter.
Green should go to the frame of the filter...
Black -> Brown = Hot
White -> Blue = Neutral
Check between the power pins and the ground pin on the power cord for resistance, it should have no continuity. (on cord)
