SavePointVG
Hey gang
Doing a Galaga restore and Im in the home stretch just running into some weird electrical problems while getting the power supply hooked up. This particular supply has an outlet to plug the monitor into instead of just having the black/white molex connector. My issue is this. My machine will turn on and give image for about 5 minutes or so, then cuts out. I still see glow from the neck, I can hear the hum of power through the board and through the power supply. The problem was first resolved by discharging the monitor and turning it back on. Same issue, image for 5 mins or so then cuts out. Having trouble getting image up again, could this be a flyback problem? When I discharge it I hear the loud pop of electricty.
Any insight would be helpful thanks
