that's a V. Hold issue, is V. Hold not adjusting? if you had a solder break either at pot or XY card header you would have vertical collapse
adjusting vertical hold and it looks good…. But it still flickered and horizontal width needs to be adjusted. A little off screen.that's a V. Hold issue, is V. Hold not adjusting? if you had a solder break either at pot or XY card header you would have vertical collapse
The board is 40+ years old.....
Some TLC would do it good.
The monitor can use new caps.It still sort of flickers and I notice the brightness going up and down on its own. Check the video.
As much as I hate inducing another problem, I feel the monitor could use new caps.
Thoughts?
that's just your phone cameraIt still sort of flickers and I notice the brightness going up and down on its own. Check the video.
Thoughts?
