Depends on the Megatouch. The old ones are standard resolution and will work just fine. The later Megatouchen are based off PC hardware, and use the high resolution monitors. But the early Megatouch hardware is standard res.
So I finally picked up a megatouch IV with a standard resolution monitor. Any one have any pointers before I swap these monitors out or should it be pretty standard? I have replaced at least 3 monitors in the past so I am not brand new to this...just curious. Thanks!
