I have a Galaga bootleg CPU I'm working on. There is a wire on the board soldered to the leg of an IC. Can someone tell me where the other end goes. To the Daughterboard?? Or??
Hopefully these photos will help. Not sure it is the same version of board as yours. Basically, the wire goes under the small daughterboard, comes up through a hole and solders to the topside.
Yours looks a little different. But I think It goes to the same place. The one I have just solders in from the bottom. There is no hole for the wire to come up through and solder in from the top. Anyway i think I can get it from that. I just needed to know for sure that the wire went to the daughterboard. Knowing that and looking at the general positioning from your photos I can probably find where it came loose. Thanks for your help.
I have here the same board as in this picture, the wire goes to the point labeled "2A2" on the daughterboard. My camera batteries are charging, can take a pic if you need.
