gal,pal,82sxxx series...Can I get data in the security chip??
arkadia74
chonan, chungnam, Korea South
pal,gal or 82sxxx series are used in all pcbs for security.
To covert other games,I need the data in pal or gal
Where do I get the data in the chips ???
I do not like emulator developers and rom dumpers.
Because they never release data in pal,gal...
If the security bit was programmed as is usually the case, you will be unable to do a simple read of the fuse map. Depending upon the game you may be able to locate a reasonably priced substitute or original for that matter.
The more complex devices have internal registers with feedback and cracking them will take an extreme amount of work. Sometime an easier path is modifying the rom code to bypass the security chip altogether.
Bill
