mcandrewsoun
Couple of questions... The game is eliminator.. Using my scope in XY mode, I can see the game playing..
1. Should I be able to see the Game playing using the Scope on the Monitor deflection outputs, or does the G08 modify the signal?
2. I get output signal (measured at the Fuses) with the deflection transistors connected, and the yoke disconnected. When I connect the yoke, the deflection goes to almost 0.
All the transistors meter out ok.. It only affects Q601/Q701 and higher.. Q600/700 seem unaffected.
Andrew
Andrew
