G08 Deflection Rate
cavnex
Donor 8 years: 2017-2024
Sammamish, Washington
Does anyone have a numerical listing for a G08(-003, not -105)'s deflection rate?
Example:
The WG19K6100 is listed as having a deflection rate maximum of:
"X" amplifier = .05 inch per microsecond, "Y" amplifier = 0.0375 inch per microsecond
[This can easily be represented in volts/microsecond given the fact that it's a 19" monitor and X is -8V to +8V (16 V horizontal span) and Y is -6V to +6V (12V vertical span).]
(I've had several days of outrunning the 6100 at deflection, and having the 6100's numbers were critical. Having the G08's numbers for max deflection rate would be darned helpful.)
Thanks - just in case anyone knows. :)
Greg
