Finch
Ok, so I got my G07 back up and running a bit. Before it died again And turned it on to test it, tested the B+ and turned the screen brightness way up to see if I got raster. I do, but it has bright diagonal lines across the screen.
Is this normal when there is no video source? I don't have anything hooked up to it right now. I looked on the g07 flowchart and it says to check x303 and x304, but I can't tell if thats only if you do have a video signal running to the G07 and that's all you get, or if the diagonal lines are always bad.
