Fudd Active member VAPS Joined Jun 5, 2006 Messages 2,382 Reaction score 13 Location Kalamazoo, Michigan Dec 18, 2010 #1 i was adjusting my G07 horizontal width with a plastic adjustment tool and zap! i replaced x901 and x902 to start and its still the same. Where to look next? Attachments G07.jpg 94.8 KB · Views: 39
Peale Active member VAPS Joined Sep 1, 2003 Messages 3,469 Reaction score 15 Location Brattleboro, Vermont Dec 19, 2010 #2 There's a small wirewound resistor near the heatsink (I forget the number). It may have gone open. Check it.
OP OP Fudd Active member VAPS Joined Jun 5, 2006 Messages 2,382 Reaction score 13 Location Kalamazoo, Michigan Dec 19, 2010 #3 Turned out to be FR401 got shorted. Can you buy these from mouser? i need to replace it from the board i stole it from.
modessitt Volunteer: Encyclopedia Submission Moderator VAPS Joined Mar 22, 2007 Messages 33,414 Reaction score 325 Location Austin, Texas Dec 19, 2010 #4 It's just a 69-ohm 2-watt resistor. the 68-ohm 2.5-watt on mouser should work...
Peale Active member VAPS Joined Sep 1, 2003 Messages 3,469 Reaction score 15 Location Brattleboro, Vermont Dec 19, 2010 #5 Fudd said: Turned out to be FR401 got shorted. Can you buy these from mouser? i need to replace it from the board i stole it from. Click to expand... You mean it went open, right?
