- Joined
- Aug 3, 2009
- Messages
- 5,152
- Reaction score
- 534
Last night I installed a cap kit into my G07 CAO that was hacked into this cab I have. I was trying to fix an issue where the monitor shrinks vertically after about 30 mins.
There was one "two wire plug" that I thought I had correct but was questionable when I put the chassis back into it. I did not label the previous (someone kick me) orientation when I took the chassis out. Well the pins were numbered so I plugged it in the way it was labeled.
I smoke tested it cause I was confident from doing a G07 before and nothing came up. I figured that it must have been this one plug so I reversed it and the tube fired up.
Sadly the monitor now fires up vertical shrunken picture.
Froms G07 Flowchart says that I should check output transistors X401 & X402. Does this sound about right? Could I have fried these from reversing that plug or maybe what was already going, is now in fact now fried.
Well, the good thing is that the picture that I do have is nice and bright.
