obitus1990
Do all G07-CBO monitors use the same tube type (19VJTP22)? I recently obtained a G07 that is housed in a WGK4900 frame (all the labels are for that monitor), and the tube is encased in some kind of shielding. I can't see the tube number on it, unless I disassemble everything and remove that shield, which I really don't feel like doing. All I can see is a large red RCA label on the tube near the neck because it's not covered by the shielding. The tube could use a rejuve, but before I do it and mess it up due to incorrect settings, I wanted to ask if this monitor used different tubes or if they were all made with the same model CRT.
Thanks!
Thanks!
