G07 Testing HOT...Driving Me Crazy
NCC-1701
New Jersey
I tested the HOT in circuit, placed my Black lead on the leg closest to the Flyback and my Red lead on the other leg, got a reading of 002, basically shorted, removed the HOT from the chassis tested each leg both ways and I get a reading of 051, not positive but I remember reading somewhere that it should read 151 to 600 in circuit, hate to replace it if it's good.
black lead to the outer case and red to each leg.
Peace
Buffett
What reading is considered good, right now I have the HOT screwed into position, attached to the G07 chassis, wires from both legs are not soldered on, need to know if I should solder the wires back onto the legs, if I were to test the HOT off the chassis would I repeat the same process.
476 & 510 same reading wires on, wires off, guess HOT is good, now I need to start another thread due to the fact I have no neck glow, and my B+ is reading 152VDC. Thanks Buffett appreciate it.
Insulator? I stuck my tongue in there with the monitor powered on, bet you thought I was a slow learner.lol seriously, yes insulator was on to prevent shorting
