G07 sync upgrade.
Finch
Santa Cruz, California
I got my Bob Roberts repair kit for my busted G07 and I'm probably going to start work on it tonight. I see in his directions he has a mod to upgrade the G07 to work on newer games.
The monitor is hooked up to Gorf right now, but it's not working, so the only thing I have to test it is a Neo Geo MVS board, or a Sega Genesis modded for RGB. Does this mod effect the monitors ability to play old games properly, or does it just add the ability to play newer games?
The mod will be fine in older games its an upgrade to take out some curl that could be produced from certain games
awesome, thanks on the heads up. I'll probably go ahead and do the mod then while I'm working on it anyways.
Any clue if a RGB modded Genesis will work on a G07? It should, works on my Sony PVM.
