texasmame
Have a G07 that had too much red. Recapped and the only thing that changed is that the red looks much nicer now.
I then swapped out the X101 and X102 (or whichever they red transistors are on the chassis and neckboard) with the transistors with other corresponding transistors for the green channel - again, no change. Also did the same for the pots - nada.
So, it wasn't the cap kit and it apparently isn't the transistors or the pots for the red color as swapping them out with green got me nowhere.
I have a G07 that I recapped and put a new HOT and power regulator, etc. and it's solid. I put this chassis on that tube and it was fine - so it's not the tube.
Between this and the damn k6100 mystery, I'm pretty beaten down.
Ideas?
Ideas?
