G07 Shuts Off - Fix
72Demon
Kaneohe, Hawaii
Just thought I would share this in case someone else has the same problem I did. I have a G07 in my Ms Pacman, worked fine for 6 months, then would start shutting down after being on for a little while about a week ago. Then it would go into HV shutdown after 2 minutes. If you would let it cool down again, it would work and then shut off again. After reading forum posts on the GO7 / G07, I inspected the transistor at T501 and found small cracks in the solder. I resoldered those two connections, and its back up and running again. Hope this helps out another G07 owner, with a simple fix.
