M_May41
- Joined
- Jan 19, 2003
- Messages
- 29
- Reaction score
- 0
I have a Galaga with a G07-CBO When I first bought the game the picture would start to scroll uncontrollably to the left after the game warmed up and couldn't be adjusted out. So I capped It and also replaced the HOT transistor and XO4 transistor. I also replaced the width coil as someone had sealed it with what appeared to be epoxy. (figured that was probably the main problem but It wasn't) When I Re-Installed the chassis and powered the game back on. Same problem. The pic has a minor but noticiable horizontal wave and scrolls to the left uncontrollably to when warmed up. Even when cold the V-hold must be adjusted all the way to the left to hold the pic stable. So what next?? I figured I'd change the vertical output transistors and see If that cures the problem. Is this what I should be looking for?? Or do I possibly have some other problem? If so what might that be?? Also the new transistors came with mica Insulators. The old ones had only heat sink compound between the transistors and the heat sinks. Should the Insulators be Installed or left out??
