Does anybody have any suggestions on how to fix this?
I was playing Ms Pacman when somebody turned on another tv when suddenly the Ms Pacman arcade started to play blind.
I used the G07 flowchart and checked F901 and F902 and both are fine.
The diodes on D901-D904 are also fine.
The Resistor on R101 is also fine at 220
From what I can tell I think the flyback is okay. There is no visible cracks.
Maybe I'm testing the hot incorrectly but when I tested the HOT using the DMM by placing two needles on the two legs I get a reading of 0.
When I place one needle on the outer casing of the HOT and the other on the leg I get a reading of 510.
Is this correct? I thought it should be a reading greater than 10 when placing the needles on the two legs and 0 when placing one leg on the outer casing and one on the leg of the HOT?
I thought the HOT was shorted and replaced it with a new one but I got the same reading with the DMM?
Am I testing it incorrectly? This is all new to me so any help suggestions or help is appreciated.
Thanks.
Thanks.
