G07 Picture is horizontal not vertical
SpamManMarc
Ohio
So I just swapped out a G07 monitor with a used one after I dropped and broke my freshly rebuilt one.
Its a Jamma game(ameridarts) and it started off showing the game vertical, which it should be, then went horizontal and won't change. It is a vertically mounted.
Ideas??
You mean it changed while it was on?
Usually if it's the wrong way, it's because you have the yoke wires on backwards (vertical on the horizontal, horizontal on the vertical). OR, it's possible the yoke spun around 45 degrees, it would be crooked though if it did that.
Yeah it started up vertical after I put it in, then it froze. I restarted it and it has been stuck horizontal since.
