G07 Pad lifted
Fudd
Kalamazoo, Michigan
So i bought a couple "dead" G07 chassis off another klover and upon inspection i can see why they are dead....on this board all the sync pins had cracks, the hot had a wire not connected, the small fuse was missing and the flyback has this pad now gone....how should i fix this? jumper wire? what gauge and where do i jump it to?
cap leg will work fine
Yup, I use clippings from capacitors and such all the time for stuff like this.
For a pin like that I usually make a small loop to fit over the flyback pin and then just bend the rest around to match the trace. Maybe even clean off a bit more of the broken trace to get a good solid unlifted repair area. Then just solder it down.
