G07 on WG19K4901 frame?
saltbreez
Olympia, Washington
Hey guys,
Any reason I cannoy mount and use a G07 chassis on a WG19K4901 frame [and reuse the WG tube] ?
I have an early WG 19K4901 that has a mismatched yoke, so the picture never will be 100%.
Well, I just picked up a G07 sans frame with a really burnt picture tube... But it has a yoke!
Any thoughts on this frankenstien monitor?
Saltbreez
you can , use the wg rings on the tube neck, slide on the G07 yoke, put the frame together, you will have to drill holes to mount the G07 chassis , but use standoffs and it should be ok
Hey not bad for a frankienstien! The Go7 fit right in, needed a couple of lifters to keep the PCB off the frame in the rear, but she lines up with the screw mounts for a WG4900 series. She comes up, good screen [needs a cap kit], a little tweaking at she looks awsome.
Saltbreez
