g07 - not turning on, no neck glow...
It's a G07, so I'd start with a rebuild kit before anything else. New flyback, HOT, reg, caps, etc etc.
In the meantime, check around for some flowcharts, they'll give you a general idea of where to look and what to look for. Might be able to get it up and going without the rebuild, but you WILL need one eventually... especially if the monitor hasn't been running in a good while ... touchiest things I've ever messed with. Great picture... but, man, what a nightmare sometimes.
Check the fuses, if they're blown it won't work.
If they're okay, check R908 or other things in the power supply section.
And of course, if this has original caps, and more importantly an original flyback, replace them!
