NCC-1701
Was working fine up until a few days ago, turned it on and no picture. I have 120vac at the monitor chassis power connector from the isolation transformer, B+ measures 152vdc, not sure if the monitor circuit went into shutdown, both pigtail fuses on the chassis check good, no signs of any implosion, cracking on the Flyback, thought maybe the HOT died, but DMM shows 476, and 510 on each leg. I did make some minor screen adjustments on the pots recently, not sure if I turned up the B+ pot by accident. I'm going to try to turn the B+ back to 120vdc, need some direction on what to check next so I don't go looking for trouble.
