G07 issues
KDAWG97M3
Georgia
Hoping someone can help....I recapped the g07 and flyback replaced.screen works and color is good, but it is blurry...the game is pole position 2 and it works, just not clear like my PP1 and the wells monitor,,,I have adjusted focus, I measured B+ (120) the width coil is not working ( I might have broke it) the screen is not centered, but again doable...any ideas on what I should do?
check for continuity from the flyback in all directions.
Did you reflow solder throughout the neckboard? In particular the pins that secure the socket to the pcb. (the entire chassis for that matter)
Did you wash this chassis or expose the neckboard to water at all?
I actually had the chassis recapped by reputable person....I can check the flyback...the PCB was rebuilt as well..yes it was resoldered..
Like I said it works and can play, but the letters/words are blurry no matter what I do...I could play with the adjustments more, but just wasted feedback prior...
No water that I am aware of
I've seen this with a new, bad flyback before.
If you have another known working one, and are inclined to tinker, I'd swap them out. I just swapped a flyback into 3 different working chassis to confirm it was in fact faulty. It's not fun, but you gotta do what you gotta do sometimes.
I will reach out the guy who rebuilt the chassis see what he says....thanks again
Make sure you didn't bend any pins over on the neck
