G07 issues
death69inc
st louis area
main issue is i have a g07 that i need to install in a Pac cab (have yet to return to location to install it)
picture was great had sync issues scrolling etc.
I have recapped and replaced pots from (bob Roberts)
still can not get the position to stick longer than maybe a minute
have tried swapping dif test sync combinations and different jamma pcbs no luck
any ideas I'm up for them
width coil seems to be unresponsive also but I'm not used to g07
most of mine have all been WG K4600-K7000 and Nintendo's so I do not know what's normal for these ... I have seen a few sync issue post for g07 but nothing that helped so far .
Other chasis has no life looking for someone to send chasis out to do not have paitents anylonger for board repairs lol
If you want, I'll do a chassis swap with you. Prices dependent on what work you've already done to it. You'll get a rebuilt chassis with hi-temp Nichicon brand capacitors (all replaced), solder rework, bench tested for at least 24 hours.
i havent done anything to other chasis no idea what others have done i would need to look at it
have 2 fried resisters now after a sync waire swap shakes head
either case looking to find values of r317 and r315
looking for schematics now lol
your assuming the scrolling is due to a issue with the monitor....you need to make sure it is a monitor problem first as it may be a pcb problem.
have tried many dif pcbs
including
black tiger
aero fighters
sf2
and ms pacman
all have same issue
and no issues with other monitors on my test rig so yes i assume its the monitor
even with the assumption i still tired swapping harnesses etc. no help
pics of it scrolling?
goes from me getting it to stop to in scan line a second and progresivly gets worse as it runs
longest i have had it still is 1 min
if you mean the resisters already replaced them .
lates info with monitor sitting horz on desk
I checked +b was on high side 128 i turned it down to 120 now i no longer get vert scrolling now i get horz scrolling
i up the +b the horz scroolign goes away but then vert scrooling starts
horz freq pot gets the scroll to somewhat stop but not for long
ok thanks for trying to help i figured it out
seems some how on my test rig the !!!! H sync !!! disconnected
_)@($)_$(*@_($*@$_(@*$_@($*!
nothing like wasting two days
all 3 where there but for some reason the h sync wire came loose from the sync wire on the jamma harness
shakes head live and learn
stupid mistakes
sorry for the bother
vert scrolling was caused by +b being to high 128 lower to 120 all is good
horz scrolling caused beacuse there was no sync connected (hooked sync back up screen corrected)
so on to the other 5 monitors I have not working lol
ok other g07 i am having issues with +b is reading the same on both sides of ceramic transistor so i take it the ceramic transistor is bad? Bad HOT ?
hmmm
....... its been to long I need to freshen up on monitors a little
(2SC1106) is what i called the hot
the ceramic is above it i was talking about
ordered a rebuild kit from bob
if i dont install all parts ill ahve them in stock lol
thanks for the clearification
had them reverse thgoutht he regulator was next to the flyback and hot was where you check +b
but make more since the regulator would be near power source and hot would be near the flyback
ok put full rebuild kit from bob on thischasis and still have same issue
flyback widthcoil fuses hot and regulator plus capkit
and still getting 158 +b reading same as before i changed anything
before asking why change it all
width coil was broken both fuses where bypassed
went ahead and replaced hot and flyback because its cheap enough and figured i dont want the monitor to go down in a month lol
but either case still no go on this one
figured the regulator as stated by Dokert few posts back was the logical part to replace but no help
knocking around if i want to try the reg in the working chassis to make sure its good
or looking at the x901 as it traces back to b2 and b3 which go to both sides of the reg
im getting 47ohm on r908 from the resistor calc its right Y V blk R Or
all resistors look orig and none are burnt up ... putting it back
getting 83 hfe on the x901 datasheet shows min 40 typ 80 max 250
83 falls aroumd typical range correct?
as far as the diode setting and testing
red base
1.98 to 1.67 drop 0.3 blk collector (seeems little low)
1.5 to 0.6 drop 0.9 blk emitter
blk base
1.4 to 0.5 drop 0.9 red collector
1.3 to 0.4 drop 0.9 red emitter
