modessitt
G07 issue...FIXED!
EDIT*** See last post for resolution ***
I have an unknown history G07 19" chassis. Has new-style flyback. I've put in new caps, and checked the HOT and VR but they seemed okay. Touched up cold solder joints but it was still dead. B+ is running about 160vdc.
Did some more solder work and stuff, and had a B+ of 135vdc.
Swapped out the VR and had a B+ of about 124vdc. HV is present. Cool. I hook up the chassis and find I have no vertical deflection. Okay, that should be easy to fix.
I find FR401 is open. I replace it, and upon power up it heats up and goes open again. I replace it with a 5W version this time, and it now stays good, but now R420 burns up.
I replaced both vertical deflection transistors and R420, and burned up R420 again. I replaced R420 with a 1W version so I'd have more time to troubleshoot before it burned up. Eventually I determined that D401 was open. Got a false reading in circuit, but no readings out of circuit. Replaced D401 and no more burning parts.
BUT - my B+ is back to 160vdc again. If I take D401 out, it goes down to 124vdc. WTF?
If I pull X701, it works, but b+ is still way up at 153vdc. I've gone over the entire power and vertical sections, replaced all the caps again, and measured every single resistor, diode, and transistor - and I'm not finding much of anything. I did find R905 to be an 8.2k-ohm resistor, when the schematic calls for an 18k-ohm resistor, but changing it to 18k didn't make any difference.
Anybody for any bright ideas?
