jgeiger
Working on a G07 and I believe it is going into shutdown and have not been able to figure out what to do next. Heres whats going on.
Did a cap kit from BR.
Replaced the pots from BR.
Replaced the flyback and HOT from BR.
Powers up with 120VDC B+ on the white ceramic resistor.
When checking the voltage on the case of the HOT the meter keeps resetting.
Im getting a high pitch whine out of the chassis.
No picture, no neck glow.
I pulled X701 with no change.
Checked R908 and it is within range.
Double checked all the caps and they are aligned correctly.
I think thats about it. Next is to start checking all 900's on the chassis. Any other things I can check?
Thanks.
Thanks.
