G07 Horizontal Width issue
Malice95
Howell, New Jersey
So I have a freshly capped G07 that is having a horizontal width
issue. The hor width coil (which was replaced) only makes minute
adjustments and the left/center/right selector seems to work a bit but
doesnt affect the width of the screen. Any ideas? its not that far out...
just needs to shrink a tiny bit and move left.
Thanks,
Mike
attachment.php
attachment.php
Aww, is that the one I did for you? How's it working otherwise? It looked good in my Galaga cabinet, but sometimes you have to adjust them for each cabinet. I think there is a cap you can change the value of to change horizontal width.
Yes it is.. I ended up shifting the plastic bezel over a 1/4" and problem solved.
You did a great job.
I do have to check the B+.. I assume you set it to 120v?
