G07 high B+ argg
Talon2000
Princeton, Texas
Got a G07 Original condition unknown. Now has new cap kit, new flyback, and H coil.
No heater glow, and B+ is 168V
Removed X701 No change
Found only one bad solder joint on T501 No cracks found.
Voltage on X01 case to ground 168V
Replaced X501, and IC501 No change
Replaced X901, 902, and X701 No change
R908 good
FR901 Good
Suggestions?
What is the B+ reading on both sides of the big white resistor? Is that resistor measuring out at 220-ohms?
If everything else is good, but you swapped the wires on either the BR or the HOT, this could happen...
