I have searched the forum and I have found the same issue in an earlier post, however, the suggested fixes didnt work for me.
Monitor is too bright with white lines.
The screen adjustment seems to make a slight difference but ultimately fades back to too bright
What I have done:
1. Capped the chassis
2. Checked for cracks and cold solder joints (fixed a couple)
3. swapped x303
4. B+ is 120 / 145
5. swapped neckboard with screen and focus pots
6. swapped tube
One of the fixes for this in a previous post was a crack at pin 6 on the FB. The connection is solid, however, the pad is slightly lifted. Measuring with my meter, I do have continuity.
Any thoughts or suggestions would be greatly appreciated.
Tom
What I have done:
3. swapped x303
4. B+ is 120 / 145
6. swapped tube
Tom
