G07 ground help PLEASE..
vintagegamer
Donor 2024
Bear, Delaware
I have a couple extra yellow ground straps lying around, and would like to add them to my Moon Patrol to see if they resolve the sync issue I'm getting.
Can someone tell me where the best place would be to connect one on the chassis frame, and if I do so, where would I connect the other end to? The transformer? I have tried to research this on my own but am not getting very far.
Thanks in advance.
If you are just trying to ground the frame, just find any spot you want to connect it. Then you need to connect it to any point that is connected to your earth groud. It would probably be somewhere on your power brick.
Here is a link from Bob's site, it should give you some insight:
http://www.therealbobroberts.net/acwiring.html
assume all green wires are like your yellow flat strips
